dhollins 0 Posted May 21, 2009 Can someone clean this image up for me so I can cut it. Thanks grasshopper.eps grasshopper.eps Share this post Link to post Share on other sites
midwaste 4 Posted May 21, 2009 It's probably going to be easier to go back and re-trace it better. I tried simplifying the path to remove some of the smaller elements and it didn't come out well. If you can post the original, Ill see what I can do with it, as I am looking for something similar to that. Share this post Link to post Share on other sites
dhollins 0 Posted May 21, 2009 Thanks. This was the original. Share this post Link to post Share on other sites
Mr Peabody 0 Posted May 21, 2009 Cleaned it a little - still could use some more. Graphic1.eps Graphic1.eps Share this post Link to post Share on other sites
midwaste 4 Posted May 21, 2009 Thats better than I did. Thats a pretty low-res photo to start with.. Share this post Link to post Share on other sites
dhollins 0 Posted May 21, 2009 Thanks Mr Peabody. That is much much better! Share this post Link to post Share on other sites
dhollins 0 Posted May 21, 2009 I sure would like to learn how to clean files up like that. What program did you use? Share this post Link to post Share on other sites
Mr Peabody 0 Posted May 21, 2009 You're welcome - I used Corel x4 Share this post Link to post Share on other sites
