vectorman
grafhic "jump" during cutting in the big one
houdi and a happynew year
i hope u have a good irs report this year..
anyway my new 1351 is a bit out of tune so many parameters..................
when im sending big cuts like 21 meter
the grafhic work jump i mean that one element is not cut in the place it shuold be ,it like moved else where and fuckup all the vyinil ???WHY ;D
the artwork is 40K size
the grafic is perfect
im using the 9 pin cable
Guest
Have you tried a different large graphic just to see the results? Does the machine cut fine when you are doing smaller graphics? Have you tried to recreate the problem with a different cutting software? What software are you using now?
well for your segest
i change the program from my good old "casmet" an early vershion of flexi
to SBE and i got the beutifull clean 2 meterlong whith no slyding cuts...........
thank uX2
