arteinternational
Posts posted by arteinternational
Gonna do the change to GraphtechStudio for sure and try it out.
It arrived free like you said
Thanks
Hello
This is an example of what happens
Top line is sending it with condition one and bottom line is the correct one that doesnt skew when i send it alone. btw it improved changing the force to 15 but the last line got messed up (see the pic)
Not sure if you can see thats the lenght i been using for condition 2....Blade looks fine
thats really good to know
Im in a bit of rush but ill try and send blade pics tomorrow
Thanks!
Hello
I tried changing the wheel pressure to outsidewheels strong...inside wheels medium and with no change on the skew problem.
This is the setting for condition 2, I normally have the cutforce on 32 but was testing it on 36
4 minutes ago, Dakotagrafx said:cutmaster is a plug in - graphtec pro studio is just like full fledged flexisign pro except it doesn't have the RIP feature for our wide format solvent printers - so like comparing grub hub to a 5 star restaurant
Gotcha
- 1
1 hour ago, MZ SKEETER said:I was looking at the pinch roller adjustment in my user manual and it is best to have the 2 outside pinch rollers with more pressure than the inside pinch rollers. There is a page in the user manual for how your pinch rollers should be. And I don't know if you knew it, but you can get FREE Graphtec ProStudio software from Graphtec for that vinyl cutter. It is over $1000 software, like Flexisignpro.. I only use Flexi software with my Graphtecs. Also, you don't state how you set your blade depth. Hopefully blade depth is not dragging on your vinyl.
https://www.graphtecamerica.com/cp-graphtec-pro-studio-request-form/
Thanks Ill let know if any makes a difference.
Is Graphtech Prostudio better than CuttingMaster?
Good day to all,
Machine: Graphtech plotter FC8600-130 64"
Trying to find a solution when i send my projects normally 50"w by 60"h registration marks made with Ai Plugin, I assign condition 1 and condition 2 in CuttingMaster3 normally and it cuts well except when condition 2 starts...sometimes the first line cuts good but going up it begins to skew upwards each line it changes more eventually damaging the first cut.
All wheels are in their respective position with medium pressure.
One solution ive found without problem is sending condition 1 separate from condition 2 so each one sseparately works perfect... but for speed i want to send both at the same time. What could be the problem...a fix besides sending separate cuts Any input would be appreciated.
Thanks
Graphtech Condition 2 skewing
in GraphTec Cutting Plotter Support Requests
Hello
wanted to give an update about the "problem" i was having.
Looking on the condition settings i found the distance adjust x: being 0.45% and y:0%
I changed x to 0% and it has fixed the skew problem
gotta be careful when editing those settings
thanks all for sharing
