reeves1985
Posts posted by reeves1985
my white plastic grooves look just like your red plastic grooves.- The mount Does Not slide into the plastic- I thought the same thing. the cutter simply sits on top.If you look closely you should have small holes for the screws to go into.
I managed to figure that bit out after a good while head scratching!!.
Can I ask
did your centre support fit correctly?
The two legs have 4 holes in the middle (for the centre brace)
then there is 2 holes on one end which one hole lines up with the bracket I assume you screw them together
I have had to turn one leg upside down though to get the centre brace to fit properly
so now one one side I've got those two holes at the bottom near the feet!
I'm to trying to work out if I have some how received a wrong leg as it looks like each one needs to be slightly different to fit with the shape of the centre brace
In fact come to think of it they've definitely sent that stand and I'm sure it's wrong because wheree it mounts to the cutter, mine has like a square groove, which I assumed the mount slotted onto but it doesn't.
Looking at the pic above that may be why as the white pcut is flat where the mount goes
here is my Pcut and stand- hope these help:[img=http://1.1.1.1/bmi/i768.photobucket.com/albums/xx326/Jasonburns01/photo%201%209.jpg]
[img=http://1.1.1.1/bmi/i768.photobucket.com/albums/xx326/Jasonburns01/photo%202%206.jpg]
[img=http://1.1.1.1/bmi/i768.photobucket.com/albums/xx326/Jasonburns01/photo%203%201_1.jpg]
That's the stand I've been sent
But my pcut looks like the laserpoint
so not sure if it's the correct stand
Also I notice the screws in the side of the legs holding the cutter bracket
I had to turn one upside Dow to get the centre brace to fit
HahaYeah, I'm outta breath reading that sumbitch...Well I've managed to get this son of a b***h up in some form although I am fairly certain the shop sent me one wrong leg as the only way it fits together is with one upside down.
Won't cause an issue as the stand is as solid as it's ever going to be, but I'll be bringing it up with them.
It looked like it may have been a demo/display one anyway as it was just slung in a box and there is numerous bolts that have no home and a few of the sizes were short, so seems to add up.
That is one long sentence, reeves....Oops sorry typing on the mobile doesn't do any good
- 1
I must admit it looks a lot like the laserpoint without the laser but that's about as far as my knowledge on that part goes
I seem to have got somewhere by actually putting everything together backward
starting from cutter mounting down as a test
The thing that's got me scratching my head is the actual side legs have a channel either side and assume if figured out the right way around but the centre support only fits on one end and doesn't line up on the other unless you turn the leg upside down which will work fine bit I'll then have 2 holes on one side at the top and the other side will be at the bottom
I think they should both be at the top because one lines up with the cutter mount bracket
It's all a bit strange
Ok no problem worth a try though as their forum is dead and will have to wait until Tuesday for help
Thanks anyway
<blockquote class='ipsBlockquote'data-author="Mz SKEETER" data-cid="390347" data-time="1428168642"><p>
Maybe post some pictures of where you are at....or what you have.. UScutter is not the same as UKcutter. <br />
<br />
This is the stand set up manual from UScutter for Pcut. <br />
<br />
<a href='http://www.uscuttersupport.com/downloads/Support_PDF/CutterSetup/Pcut/Pcut_Stand_Guide.pdf'>http://www.uscuttersupport.com/downloads/Support_PDF/CutterSetup/Pcut/Pcut_Stand_Guide.pdf</a></p></blockquote>
thanks
I understand ukcutter is not uscutter I just hoped someone could help as I thought quite a few of these creation pcut were the same/similar etc
I've looked at those instructions earlier but they didn't help much
I'll put some pictures up later but as a general idea this is the point I have got to
I have:
the screws and locking washers etc
2 foot pieces with wheels attached
The 2 side pieces (legs) with the 4 holes in the centerfield and 2 holes to one end
the cutter mounting bracket
2 roller bars
and 2 big silver round end pieces?
Right
the legs have a channel running top to bottom on both sides one is slightly different to the other (but both legs identical)
these have four holes in the centre and 2 holes at one end (I'm not sure which way these go) and also which side the centre suppoDr is supposed to fit as it seems I can only get the centre section to fit one way
The cutter mounting bracket again looking at the instructions and the way it goes on the top I just cannot get it to fit together
I guess what I am really asking is does anyone have one on a stand and can show me how it fits together I should then be ok to assemble
I've had a creation pcut cto360 nearly a year and recently purchased the floor stand
The problem is there was no instructions and I can't for the life of me get the thing together
I have looked at the instructions online but they are too vague to help
The cutter doesn't seem to want to line up with the bracket holes and the legs only seem to be able to fit one way
Any help would be appreciated
Oh and the cutter was purchased from ukcutter as well as the stand
I sent pictures which they requested to make sure it was the correct stand for my machine
Having a major issue with sign cut and my pcut
I have everything set up so it works but signcut will never complete a full job it just stops 3 quarters of the way through and goes back to the "online" state
My plotter is directly connected through USB with correct updated driver installed
Initially to get the plotter to cut I had to set the baud rate to 38400 and every job which fails in signcut finishes complete and correctly in signblazer so my plotter is communication with my computer
It doesn't matter if the job is a large one or small one in signcut it will still fail
A side not I couldn't get my plotter and pc to communicate with any other baud rate including 9600
I don't have a serial port so that is out of the question at the moment
Any help appreciated
Thanks
I think that baud rate was wrong I set to 38400 and it works
But I had the same issue and i was beginning my head against a brick wall and saw something somewhere regards the baud rate and it worked
Although I don't have much luck using the cutter with signcut it always stops halfway through the job
I have had more luck with signblazer elements which seems to work fine although the program itself is rather ugly and hard to navigate and get used to
I wanted to use signcut because of the plugin for illustrator you can just export the design and that's it done with
Signblazers a mess in that aspect
I solved the problem
I had to raise the baud rate in both device manager and signcut to (I think) 1480 and it worked
- 1
i am also having this issue
i have double checked that the baud rate and comm ports match but still have no luck
anybody have a solution
stand installation help
in Creation PCUT Cutting Plotter Support Requests
Thanks
that was exactly my thought
I must have been sent a wrong leg because
when ivput the narrow channels correctly facing the inside. Only 2 of the screw holes line up on one side.
The other side all four line up,
so I can only assume whilst both legs look the same the are actually slightly different.
On closer inspection it looks like those 4 holes as in your last picture are slightly offset in the narrow channel.
So must be a specific side for each leg
Will defina rely be taking this up with the supplier (ukcutter)
Thanks for your help!
