paulzeee
Members-
Everything posted by paulzeee
I understand that, i should have been more clear. The only way i know to vector things is with the pen tool in AI and it seems like so much work. Thank you so much
I guess maybe my issue is i dont know how to use any of those files. Any help on this?
Looking high and low. Google Here Everywhere
The Analog graphic still crashes SignCut, the 32 graphic works now. Thanks for the help, ill try saving them in older formats if im having issues. My version of signcut is 1.04 for windows xp. I'm just now updating to 1.07 hopefully this works. After installing the update SignCut is running WAY better. My other question: how do you make it repeat across the vinyl instead of lengthwise ??
What are reasons that signcut would crash when importing an EPS file? I found a thread and it mentioned to get the latest update; I did and it still crashes with some files. Also, how do you make repeat cuts across the vinyl? (opposed to down) Thanks
Ill check for bitmaps in the files, thanks. They have never been able to successfully open in SignCut. Here are a few that crash SignCut Analog2.eps Thirtytwo.eps Analog2.eps Thirtytwo.eps
I have an issue with an outline sticker of a font. The only issue i foresee is with letters like the A,B,O and R where the small pieces are needed. Is there anything to put over the sticker to ensure a long lasting application? The stickers are put on a powder coated metal. Clear coating over the sticker isnt completely out but wanted to check to see if there are options out there. thanks
the wear on what its on is pretty high (stunt bike parts) and also the size of font/ the middle of the "A" for example. a tiny sliver could easily come off (or am i wrong with a higher grade material. i've only worked with 651 or equivalent)
I drew this graphic and cut it out with SignCut but it cut along the exact line in the drawing. I was expecting it to cut around the line instead of on it. Is this part of the software not being setup correctly or is it the drawing? Thanks (dont mind the text, the image is from a computer that doesnt have the font i originally used)
Graphic sharing thread... Start your EPS collection here!
paulzeee replied to firemalt's topic in Graphic Requests
Tracking skydiver. First time using AI or the pen tool tracking-final.eps tracking-final.eps -
I bought a PCut and it came with this stand: I think the brackets are drilled wrong cause there are two issues with them. - The provisions on the bracket where the cutter mounts dont line up - The provisions on the bracket to mount to the stand dont line up If the bracket is mounted like this: ...on the outside, the roller is too short. If the bracket is mounted the other direction (like the directions show), on the inside of the stand then the rollers are too long (if i redrilled the bracket this could be a work around) anyone else have this issue?? I called PCUT and their support wasn't the best.
Thanks for those pictures guys! I finally figured it out. I had the legs backwards.... If you look closely there is a side with a wide channel and a narrower channel. The narrow channel faces in making the bracket mount closer to the legs allowing everything to fit. Now im waiting for vinyl and im sure ill need more help. Thanks again y'all
Gotcha, when i get home ill take pictures of them mounted like that as well. Even with them mounted on the inside of the stand there are still issues.
They do, but when i have them on the inside then the rollers are too long. I'll take better pictures.
In that picture the machine is on the floor.
Yes. I'm either reading something wrong or the brackets are drilled wrong. I've tried every combination i could think of.
