flybob
Posts posted by flybob
My receipt of the 630 I got says license key is included below, however there is no key. How do I get the key.
Not sure what happened either. Here are the details in hope that it may solve another customer's problem.
On power on. it appeared to be trying to move carriage but did not move, Carriage moved freely by hand. No red switched pressed. It only made a pulsing sound. Fan either did not run at all or ran very slow pulsing with the sound made by the carriage stepper motor. No display. When I checked the power supply with normal pwr supply connections, 5V terminal rose to 5v then quickly decayed to zero and continued to do this. All pwr supply terminals were hot glued, but screws were not tight before gluing and positive supply wire to the fan appeared to be shorting out supply. Fix was simply removing and carefully reconnecting supply terminals. Had to restrip and bend fan connection to prevent more shorts. So far so good, three cuts.
Did that ( created a ticket on Thurs ) and haven't heard anything. Went to troubleshooting FAQ's and one suggested opening bottom and checking connections. Did this and all plug connections looked OK. As long as it was open, put a scope on pwr supply outputs. 5V supply turned on and immediately decayed to zero then continued to cycle on and off. Disconnected all the connections to pwr supply output and checked supply seemed OK. Reconnected one at a time. Appears to be working now. Looks like it was short caused by positive fan supply connection. All connections to power supply were marginal. Spade lugs were incorrect size for supply mounting space so one side of each lug was cut off to make them fit. Supply wires for fan were simply stripped wires stuck under the connection screws. Fan supply connection appeared to be causing short in supply.
Yes carriage moves freely and roller moves freely. Carriage is on the middle of the slide so no red buttons pushed.
PCUT630 arrived today. Removed shipping cable ties to free carriage plugged in to test and no display and making pulsing noise like stepper motor is trying to do something. Any ideas.
PCUT630 DOA
in Creation PCUT Cutting Plotter Discussion
One more question.
Invoice says authorization code for SignCut Pro will be emailed, email referenced it, but no code included.
