peteyf
Members-
Everything posted by peteyf
Does anyone know a FREE website to get monogram? Circle, interlocking..I need true type fonts. Thanks Petey
Hi, I have a Pcutter and have used SignBlazer in the past.Tonight I turned on my Pcutter and opened SignBlazer and hit the cut button and it says"Can not open output drive. Error initializing cutter? Can you please help. Thanks Petey
Need Help on Creation PCUT 24-25" Vinyl Cutter Plotter
peteyf posted a topic in USCutter Refine Cutting Plotter Support Requests
Hi, I bought this Pcuter back in 10/09. It has been a great cutter. I use this cutter a lot to cut vinyl letters, heat transfer or designs and have not had any problems until today. Today I was cutting a roll of Easy Weed material and it worked great...than the blade would cut some letters and some were not being cut. I than put a new blade in and set the pressure it little bit higher to 140 and turned the machine off for a while. Turned it back on...worked great until half way...than it looked like the pressure was letting up and the cut was very light and I could not weed. Can you please help? Thanks Petey -
peteyf replied to peteyf's topic in USCutter Refine Cutting Plotter Support Requests
Thanks ALL for your help. I turned off my machine for a while...put another blade in...and it seems to working fine...for the moment. I will see what happens Thanks again, Petey -
Cutting strip? Is that the stip where the ruler is? -
They just put another spiral up on the Clker website that works better. Thanks for your help. Petey
Hi, I am looking for a vector clip art of a spiral that is black and white. I have looked all over the internet......I found one thick one (Clker) which was really good, but it has a shadow, and could not make it clean without the shadow on the bottom. Thanks for all your help. Petey
I am looking for the SEC football fonts. The T for Tennessee or the G for Georgia....etc....or Something that would be close to it. I want to cut all the SEC fonts out in vinyl. Thanks for you help.
Thanks ALL for your help...YOU ARE THE BEST!
Hi, I am looking to download the Boyz R Gross font. I need it to do some vinyl letters, and sign blazer and ink scape do not have that font. I found it in Dafont...unzipped it, but I can't open after that??? Can you suggest something to do Thanks for your help. Petey
Yes...I did extract it. When I open it up, I see all the different sizes, but It seems like it is locked, and It won't let me import it into Sign blazer.
Hi, I am looking for Neoprene beverage can wraps with the Velcro on the ends. I am looking for a lot of different colors and patterns that I can either embroider or heat press. If you know of a place that sells wholesale, I would greatly appreciate the help. Thanks Petey
Hi, I am looking for free vector clip art work. I am doing party favors for a party, and I am looking to put vinyl decals on buckets...like fish, shells, crabs, hearts, and flowers. Just one color and very simple. I went to Vecteezy website, and did not really see any single free art work that I was looking for. If any one knows where I can go to get these and then I will import them into SB. Thanks for you help
Hi, I am looking for a small football...maybe 1' that I can use with Signblazer, that would be vectorized already. Thanks so much for your help. Petey
AWESOME...Thank You
I am looking for designs or a free website that I can get designs that I can use with Signblazer. I have inkscape and corel draw but you have to convert them so they will work with SB. Thanks so much for Y"all" help
What I am really looking for is a small football....with nothing else with it.....that is already vector.
I am looking for the font that they use for the Braves...or something very close. Any help would be great Thanks
Hi, I am looking to a bunch of clear glass ball ornaments. Do you know where I can buy them wholesale or really cheap Thanks Petey
Thanks for all your help. I have been looking on the internet for days....and could not find much
I am looking for 25-50
Hi, I am new to the sign world, and I am making a sign for a business to be put on a window. What is a common font to use for this. Thanks Petey
Thanks for all of your inputs. I really liked the videos too.
This is my problem...The carriage is up against the left side of the cutter against to red stop button. How do I get it to reset and get it to the center? I have shut it off and turned it on but still won
I Need Help with my PCutter
peteyf replied to peteyf's topic in Creation PCUT Cutting Plotter Support Requests
Thank You so much...that was very easy :)I just learned 1 thing today!
