prettybird
Members-
Everything posted by prettybird
Thanks, do you know if it's available for free or where can I get it? Thanks!
Hi, I am using mostly the Oracal 631 matte vinyl and someone on here suggested using US Cutter brand clear transfer tape for it. Well that works much better than what I was using except I was wondering if that is what is recommended for the 631 metallic colors? It doesn't seem to stick as good to the metallic. Has anyone else had that problem too? Should I use a different kind for the 631 metallic? Thanks!
thanks!
Does anyone have a hibiscus flower that has the inside cut out?
prettybird posted a topic in Graphic Requests
Hello, my niece wants to get a hibiscus flower to stick on the taillights of her VW Beetle. I have a couple but they are all filled in solid. She wants to have the outline of the flower with the inside area open. I hope that makes sense. The brake lights need to show through still. Maybe you've seen some on some of the VW Beetles? Of if someone knows how I can reverse it so the inside is cut out and it has kind of a thick outside line left? I use Flexi and I would need it in eps format. Thanks for any help you can give!! -
prettybird replied to prettybird's topic in Graphic Requests
Wow! Thanks a lot! One of those will probably work. -
OK, thanks, I'll see if I can figure it out. I guess I'll post a question under the Flexi part if I can't get it to work. I tried outlining it and it gets thicker, but when I go the the cut page, it shows a whole bunch of lines where it shouldn't be cutting. Thanks for your help though! -
I don't have sign blazer, I use Flexi. Any ideas how to do it in Flexi? Thanks! -
That looks good but is there a way to make the outline thicker? And how did you do this? Thanks! -
That's really pretty! But I was thinking something more simple like this one I attached. But like I said it needs to cut out the inside and leave kind of a thick outside image of it. Know what I mean? (I'll attach the eps too in case someone wants it.) trflower1.eps trflower1.eps -
Does anyone have a chicken and a duck stick figure they could share?
Thank you! Those are cute! -
Need help with my SC-500
prettybird replied to prettybird's topic in Roland Cutting Plotter Support Requests
OK, I got the profiles installed to the output profile area. And I tried printing a photograph using the settings that you said you used (neron) and for output profile I used both the PGVP super and PGVP fine setting and they both still look bad. It looks like the colors are printing right, but it still looks really grainy (like there is not enough ink or like it's a low quality photo that I tried to enlarge way too big. I took the photo using 8 mega pixels and I'm only printing it at about 5"x3". Is there some other settings I should adjust still? Should I have color correction checked or unchecked? If checked, how should I set the color settings? Thanks a lot for your help! -
Hi, I have a Roland SC-500 printer/cutter. I am having trouble getting it to print pictures very good. It seems to be printing things way too dark and they look really bad! It doesn't look anything like it should. I tried printing a family picture for testing purposes and it's really bad and then I tried printing a picture I saved off of the internet and it's really bad too. If I type a word in a certain color and print that, then the color is pretty good, but for photos and stuff like that it's really bad. Any suggestions? Thanks, Deanna
Question on downloading and installing the profiles. Where do I download them to and how do I get them into Flexi? Do I just download them to My Documents or something and then add them in at the Output profile tab or the input profile tab? Thanks! -
Need help please!! Jobs holding instead of cutting
prettybird replied to prettybird's topic in Flexi
Thanks, I'll check it out. I really need to get comfortable with using the Roland too. -
Hi, I am using Flexi Sign pro 8.1 with a Seiki cutter. It was working fine until this morning I tried sending a job to the Seiki and it says it's holding and won't send it. I see under the general tab it's set itself to hold in list and the only other option is save to file. I clicked on production manager and right clicked on my job on the list and clicked send and then it said setup inactive. It was working fine yesterday. Anyone have any ideas? I have a bunch of items I need to get done today. I tried restarting Flexi and restarting my computer and it didn't help. I also have a Roland and I tried sending something to the Roland just to test and it goes through to the Roland. Under the general tab the send now option is there but for the Seiki, the send now option is not there. Please help! Thanks!!
Yes I do have the SC-500. I am still getting used to it. I did try cutting from it when I couldn't get the Seiki to work but I think it's cutting too fast so I need to adjust it (don't know how yet) and it was having a motor error. As soon as it finished cutting, it said motor error and made me turn off the machine. It did that two times in a row as soon as it finished cutting. Do you have any idea what causes that? -
That was it. Thank you, so saved my day!! I really appreciate it. -
I did delete the previous jobs that didn't work so there is nothing holding there right now. -
That's the problem, when I go to that box under where it says material size, the send now option is gone. Only hold in list is there and save to file. No send now option. -
What is the best kind of transfer tape to use on Oracal 631 matte vinyl
prettybird replied to prettybird's topic in General discussion
Thanks, I will try to get samples of all the kinds you guys mentioned to see what I like best -
prettybird posted a topic in General discussion
Hi, I use mostly the Oracal 631 matte vinyl and I was wondering what is the best kind of transfer tape to use on this? I use a kind called 'Main' that they recommended down at my vinyl store but it doesn't always work that good. It doesn't stick to the vinyl very good to pull it off the backing. Anyone know of some that works really good this this kind of vinyl? Thanks! -
Hi, is there a way that I can make the text look more bold? I am using the Scriptina font and I would like the letters to be a little thicker and look more bold. Thanks for the help!
Another question. Which profiles off of that list do I need to download? Thanks -
Ok, I will try this out and post back. As for the heater, what do you recommend setting it to? When we set it too high (like at 50), the vinyl starts to get humps and bumps which messes up the printing so I have been trying it in the 30's and that seems to work better but still get some high spots showing up in the vinyl. Thanks again, I appreciate it! -
Thanks for the replies, I really appreciate the help! I am using Oracal Orajet 3165 white glossy vinyl, I have the Roland Eco Sol Max ink (6 colors). I am using Flexi Sign Pro 8.1. I tried to print a picture that I took with my camera set to 8 mega pixels. I'm not sure what resolution that makes it. I also tried printing out a picture that I downloaded off of Canon.com because they said they were high quality pictures to use for printing. Usually the pictures are printing out grainy looking or the color is way off. I had my color mode set to CMYKLcLm, the other choices are CMYK or Greyscale. My Dither is FMXPress For rendering intent they are all set to relative colorimetric except on the first line under Bitmap it says perceptual and I don't see how I can change that and under others it is also perceptual but I can change that (but I didn't change it yet). For my color settings: RGB is set to Abobe RGB 1998, CMYK is set to US Web Coated (SWOP)v2 and it won't let me change it and Grayscale is set to US Web coated (SWOP)v2 and it won't let me change that. and 'use embedded profile' is checked. For media I had it set to SPVC-G (SOL Hi Gloss White Vinyl because I am using a gloss vinyl. I don't see any thing where I can choose a specific type of vinyl or printer. And my preset was set to SOL Hi Gloss White Vinyl SPVC-G CMYKLcLm Normal 360. I set print mode to photo and also tried super and normal. I think setting it to normal the colors on the picture looked a lot better but it was very grainy looking and still looked bad. So is there some other settings I should have for media and preset? And what should output profile be set to? And should I check the color correction box? Let me know if I need to give any other info. Thanks again!!
