Posts posted by jimcr
Where do you guys get the templates to cut the film, I buy my bulk film but have no templates. I need to cut a Left fender for a 2012 Acura TL .
Any Help?
When I switched to the other side of the boat I did a dry install in pieces, made it a pain because the top of the fish rolled slightly on a rib due to the setback and trapped air . I hate dry installs . Would have an commercial application fluid made any difference? instead of the alcohol and water.
I forgot about temp. It's still in the 90's down here. My bad.Temp was mid to high sixty's. very humid , was in between rain storms.
am I right to guess at using a higher amount of alcohol 60-70% because of the high humidity ?
This last Friday I went to install a graphic on the side of a boat , and I was having a terrible time getting the vinyl to release off the carrier sheet .
The weather had very high humidity and I was using 40% alcohol solution , and had more trouble getting the vinyl to stick.
Is this due to the humidity or a problem with the release liner.
help, where can I find templates for stone protection for autos, that I can cut on my cutter?
I am starting to apply chip guard to cars and I am looking to find templates for the autos.
I have searched and can't seem to find them. Has anyone any information on the templates.
I was told they are on line but can't seem to find them.
Looking for a wolf with a fish in its mouth, woof-n-fish . Its the name on my boat.
I am trying to find box templates for my wife, that we can cut on my cutter.she wants to put christmas cookies in them .Any websites or templates available?
what kid of shirts are you looking to get? Kind of busy right now but if I get time I might be able to squeeze in another order.
sizing
in Corel Draw
Mark try saving your work in cdr format , if you need to convert do it after you save it in the cdr format . cdr is corels native format and retains all the information .
the cdr format is also smaller in size.
If you need to save in both .
Jim
Thanks rodh2
That did it , job done . Customer is installing I will post a picture when he gets them put on . Thanks for the help.
Jim
Thanks Just setup for a test cut, going fishing right now, last nice day for a week , salmon run going on.
Let you know how it comes out .
Jim
here are the files .blue is the original
bluechrome3dshawded is the file that the cutter had a problem with, "the background color" silver.
Also is there any documentation for signit . I have not been able to find any. Not the easyest to understand . How to offset the shadows
. Jim
Ran into a little trouble trying to 3D shadow from corel with signit.
ran signit added the 3d shadow looked great on screen and paper , but when I went to cut the shadow my cutter went kind of nuts,
thinking it was a vibrator instead of cutting some of the lines it vibrated where the line should have been. and cutting smoothly others.
Took same graphic into Signblazer shadowed in3d and it worked fine.
Anyone else had any problems with corel or signit?
I Like cutting much better from Signcut but it wont' do this shadow, any help would be great.
Jim
Looking for vector clip art of a go cart , sits very low to the ground.
thanks Jim
fonts
in Fonts
can someone Identify this font or fonts
