RickS
Days Won
Posts posted by RickS
are the faces cut out to show substrate color? or is it white over the red? Looks good
the back of their heads is lost in the back ground, you might have to add some detail to finish the silhouette better if you are trying to use without a back ground color.
- 1
I would guess if you just cut this and weed the grey parts you will get the results you are looking for.
- 1
what do you need done with this?
- 1
Laser, find someone to do the job for you.
copyrite?
move the cutter out of the way so we can see the Bobcats.
- 3
Remember there is a big difference between wants and needs. do you really need it? do you only have one cutter? If you are buying a new cutter you should look at having a back-up cutter.
- 1
do a search on here, the file has been posted
I don't think $2000 will get you very far with a printer, let alone a cutter that is decent enough to do what you are looking to do.
Sig P230 compact, love this thing.
also have an XDm in 45 can't go wrong with anything springfield armory, good pistols.
MB you are awsome, that was quick. Thanks so much, hope I can return the favor some time. saved me a ton of time after I went through about 1200 fonts. Thanks again.
Find someone with a laser cutter.
I use nexus font also, works for everything I do.
- 1
Thanks, I will give that a try when I get home tonite.
Well a little update, worked just like you described, thanks for the flexi lesson. I had never used that function, now to remember it for next time. so much to learn.
How can I get rounded corners on a square in flexi, I have tried the outline feature and it doesn't get what I want.
I just need to put a slight radius on the corners. It probably is stupid easy but I must be stupid, help.
Be careful of serving food, most places require a food handlers card and health department inspections. just more BS to deal with.
- 1
In Flexi I would select the whole project, then Arrange, then Group, then select Effects, then Outline, select the width of the outline and that should work for you. -
The connector on the board should have a tab that will open the connector so the cable can be inserted and then snap shut to hold it.
I like Nexus Font, works for what I use it for.
I have done this before with no problems, I just put the tape right up next to each other but don't overlap, get it as close as you can, even a 1/16th of an inch gap is fine.
Jaybird is correct, I have the QE60+ and it is a relabled Graphtec without the contour cut feature. I have had ZERO problems with it and the flexi master plus software.
Joe, here are the files that I have used in the past. the local gun store gives these out with their logo with gun purchases.
I couldn't find a garand file, these are cut ready, also try the silhouette websites. all-silhouettes,.com, Da-Font's, ect.
- 1
In search of software for graphtec plotter .
in General discussion
Probably be easier to find an old XP computer to use just for cutting and design.
