Posts posted by SorrelWorks
Thank you both so much! I'm still playing with the settings but this has helped me move in the right direction! Cheers!
- 1
I create and cut decals and I am trying to my business going. I'm a Mac user and had been using Parallels with Windows XP, Corel Draw and Roland Cut Studio for my Roland GX-24. Corel Draw has always been glitchy - even when I used it on a PC but it has been a little worse on my Mac. Its been even worse as of late so I finally decided to search for a way to cut without using Windows-based programs and I stumbled on Easy Cut Studio.
Connection to my plotter was breeze but Easy Cut Studio cuts ragged as seen in the first attached photo. When I look at the design in Corel Draw, Cut Studio, Inkscape, Affinity Designer, and Easy Cut Studio all I see is the design in the second attached photo - no additional nodes and no control handles/bars positioned in such a way to cause the ragged appearance of the lines and corners. I cut again this morning using Roland Cut Studio and it came out as seen in the second attached photo, which tells me it isn't the plotter (also checked plotter settings and blade position) so I tried exporting as several types of EPS (none will open in Easy Cut Studio whether saved from Inkscape or Affinity Designer), PDF, and SVG - all come out looking ragged with Easy Cut Studio.
I am a novice in using the design programs beyond the basics of what I've done in the second attached photo so I assume I'm doing something wrong or missing something in the design program or export settings. Advice / suggestions / pointers?
Equipment / Software Specs:
iMac 27" (Late 2012) / Catalina
Affinity Designer & Inkscape / Easy Cut Studio 5
Parallels 12 / Win XP / Corel Draw X4 / Roland Cut Studio 1.26
Roland GX-24 (purchased 2008)Thanks!
Clear Layer Over Cut Vinyl Decals
in Vinyl
Has anyone put a clear layer of vinyl over cut vinyl decals? My designs have fine details (see attached photo) and at smaller sizes I need some way to protect those details as after test cleaning (gently and not so gently) the fine tips will pull up and if customers take their vehicle through a car wash, the small decals will be ruined. I’m using Avery 750 and Orafol 651 vinyls. I’ve contoured the clear overlays as shown here but the primary issue I have is it appears the clear only partially adheres around the color vinyl (zoom in on red circled area) - if you press with a finger nail it will fully adhere and doesn't leave bubbles but seems exhaustive to carefully press around each piece. Open to other ideas for protecting decals for customers too.
