dirtbikeflyboy917
Days Won
Posts posted by dirtbikeflyboy917
On 7/26/2018 at 8:46 PM, Dakotagrafx said:cars and plastic signs do not use low energy plastics - my reference was for the atv/motorbike market that does - for a back lit sign you should be using a translucent vinyl so the light shows thru (even trickier with printed to show properly) . if you want a solvent set up I can hook you up with a 30" roland, extra ink, laminator, vinyl for $8K located here in michigan
Thanks for the information (and offer). I'll keep it in mind, but for now, I'm really not interested in spending that much money.
Thanks!
It might for dirtbikes, but I need the plastic vinyl capabilities for more than just dirtbikes.... Thanks!
6 hours ago, Dakotagrafx said:I was thinking of covering the entire shield etc with one piece of convex and then adding your design - not putting it just under each letter - if need be after you have the piece for the plate cut cover that entire area with your color of choice for a background
Eh... Not so sure that would work. I am not just using this with dirtbikes, but with cars and other plastics. Most of the time I do vinyl signs with individual letters or symbols. I may just have to break down and buy a used printer from ebay. Recently, I bought a back-lit sign so I could illuminate my address. The actual area where the vinyl is applied, is plastic. I need to be able to have space visible around the numbers for the backlighting. I'm thinking the only way I can do that without the printer is using your idea, and cutting the individual characters out. Thanks for your help!!
2 hours ago, Dakotagrafx said:not likely - all of the stuff I have seen for that is for the solvent and latex printers - like convex, substance makes a few - and 3m makes some - you could cover it with the printable film and then lay your vinyl on that base
Interesting idea. I guess the only concern I have would be when I have individual small letters, but I guess I could stack the letters on top of each other. Thanks!!!
Is the Oracle 951 any good for low energy plastics? I'm trying to find a product with color options (I don't have a vinyl printer), but that also adheres to plastics (mostly in cars and small engine stuff).
Dirt Bike Template KTM 250sx
in Graphic Requests
At this time, I'm just not ready to spend that much money. If I change my mind, I'll PM you. Thanks a lot for your offer!
