Posts posted by Vinylfreaks & Co
i have it up to 3.00mm and it still doing it
1 minute ago, Dakotagrafx said:not sure as I use a servo motor cutter that doesn't have that problem but if it were me after setting my blade as described in the 8th post down I would try doubling the overcut and try that . . . I don't do metric or macs Nor scalp for that matter
lol i use 2 of those
what should that be because its set to default which on here is 1.00mm
1 minute ago, Dakotagrafx said:how did you set your blade exposure?
do you mean how far does it stick out of the blade holder ?
i also don't know if the setting are changing when i change it on the computer to the cutter is there anyway to let if they have actually changed ?
it doesn't seem so i was on the default setting 0.30 then went to 0.20 and nothing changed.
1 minute ago, Dakotagrafx said:so you are saying changing the offset did nothing one way or the other on the ears?
23 minutes ago, Dakotagrafx said:try adjusting your offset to get the corners co cut correctly
here is the link to manuals and instructions for the titan series
https://support.uscutter.com/support/solutions/folders/14000106614thank you for that but it didn't help me fix the problem i applicate the attempt tho.
Hi Everyone, i am semi new to the vinyl cutting thing i use to work with it at my old job, but that has sense gone out of business. So My brother and have started a business doing custom stickers and apparel. we purchased a titan cutter second hand not knowing how far we are going to with this. but it came with no instructions. i have it setup but overtime i cut a test with the test botton on the cutter the test has these little like dog ears on it in one side of the inner triangle and another on the bottom of the cutter most cut. is there any way to fix this ?
Thanks for the Help Connor
SCALT Pro 3 setting when using a 60 Degree Blade on a titan cutter
in Mac Users Board
thank you for all the input
