cutabove 0 Posted October 16, 2009 Question: Can someone please tell me why my cutter is not cutting consistent with the letters I send to be cut. Example an "O" will have a flat edge in a spot that should be round & if I cut ten, they all have the issue in the same spot. Is it the blade position or play in the cable? I've change the blade & no improvement. I'm new to this cutter and really need help. Thanks in advance. Share this post Link to post Share on other sites
SouthShoreDecal 0 Posted October 18, 2009 you should try to narrow it down a little more. is this just with text? a specific text? always on a curve in a certain direction? try a few different shapes, as symmetrical as possible and see if you can narrow it down. Share this post Link to post Share on other sites
Jay2703 704 Posted October 18, 2009 I would start by checkiing what you have your offset set to. What software are you using? Jay Share this post Link to post Share on other sites
prestonservco 26 Posted October 18, 2009 Sounds to me like a feed problem. Feed rollers too loose. Feed roller motor. Vinyl catching on a label. Something like that. Share this post Link to post Share on other sites
cutabove 0 Posted November 30, 2009 To clarify the issue. I just cut a logo, general design is, text with broken oval approx. 19" across by almost 11" tall. The text was the word MERIDIAN, the top of all letters on the top right corner of the text are consistently incorrect as if when it cuts across from left to the right & turns to go down, there is an issue. I'm using Flex-Sign Pro. The oval doesn't seem affected to the same degree the text is. It's a block style font Arial Black. Any help would be greatly appreciated. Thanks Share this post Link to post Share on other sites
