MGOMEZ
bad blade holder
i bought 2 p-cuts about 1.5 years ago, 1 as a back up. i have been cutting materials of different thickness
which requires blade adjustment, so i got the blade holder for the back-up machine out to use. i had problems that i didn't have with the other blade holder. in the bad holder the magnet that holds the blade in is closer to the end of the blade holder.when you put it in the machine there is very little space between the blade and the cutting strip. the blade is also binding up, when you push the plunger to remove the blade it dose not slide very smoothly. i need to try to exchange it for another 1. i have oiled it and tried to push magnet back but it did not help.
thanks for your help.
Guest HowardI
If this is the one you ordered, and it's new contact us to get it replaced.
I or anyone here would be happy to help you with this.
Please call us or go to http://support.uscutter.com and open a ticket for assistance with this.
Have a good day!
Howard Irwin
Support Specialist
US Cutter
425-481-3555
888-298-8143
  - Option 2
Or is this referring to the same blade that were posted about three days ago. In the thread that was locked by one of the moderators because its' only purpose seemed to be bashing USC?
Charlie
Guest HowardI
I'm sorry, if this is the same blade holder as you are referring to in the previous post then I can not do anything as this is way past warranty.
Howard Irwin
Support Specialist
US Cutter
425-481-3555
888-298-8143
  - Option 2
