edge 67 Posted June 16, 2009 Certain I'm not the first to ask this, just can't find the right thread. As a rule of thumb, if I switch out a 45 Share this post Link to post Share on other sites
tlzimmerman 11 Posted June 16, 2009 You should set the offset at or really close to what is marked on the blade container. Not sure what 60 degree blades are but it should be marked. Share this post Link to post Share on other sites
mr300s 1,272 Posted June 16, 2009 You should set the offset at or really close to what is marked on the blade container. Not sure what 60 degree blades are but it should be marked. That's interesting never knew that I just looked at the case for the 60 degree roland blades for my P-cut and it say .025mm thanks for the info Share this post Link to post Share on other sites
wwpro 1 Posted June 18, 2009 That's new for me too .... gonna adjust mine to see what happens Share this post Link to post Share on other sites
cutme 5 Posted June 18, 2009 most all blades, you will find are ground with a 0.25 offset. bb Share this post Link to post Share on other sites
NukleoN 34 Posted July 20, 2010 You should set the offset at or really close to what is marked on the blade container. Not sure what 60 degree blades are but it should be marked. That's interesting never knew that I just looked at the case for the 60 degree roland blades for my P-cut and it say .025mm thanks for the info Does it read .025 or .25? I see people typing both those numbers. I think it's .25. Share this post Link to post Share on other sites
cutme 5 Posted August 6, 2010 .25, as in one quarter of a millimeter. bb Share this post Link to post Share on other sites
