Mikuda
Members
  • Content Count
    2
  • Joined
  • Last visited
0 Neutral
About Mikuda
  • Rank
    Newbie
  1. Thank You for input but I don't see how is Your answer related to my issue? Units (cm, inch) are irrelevant here - tested it. Firmware version is irrelevant too - I did it only as attempt to eliminate this problem but it didn't change anything. There are three options in Media Size section: - "default preset" which is also too big and is independent from plotter and pretty much useless - "user defined" where I can input correct settings manually but it's cumbersome. - small button with "?" which should read dimensions from plotter. And It kind of DOES - numbers are correct but units are messed up. (don't assume what functions are "default" if You don't know the program). - FINALLY - as I mentioned - I'm working in Corel Draw. I don't need another sign making software. So Anyone else? Cutting Master users maybe?
  2. Hi there! I have very uncommon problem with my setup - not sure if it's plotter or software oriented. THE SETUP: Plotter is Graphtec FC7000-100 with latest firmware 2.10 GL - updated just recently, but problem occurred with previous version too. Set as GP-GL. Connected via USB. Windows 7, Cutting Master 2 and - if it even matters - Corel Draw X7. THE PROBLEM: After loading and measuring vinyl sheet plotter shows it's correct dimensions (mm). But Cutting Master program, reads these dimensions 10x bigger! Any clues? Please look at images: Cut Area on plotter is 532x248 MM But Cutting Master shows 532x248 CM Any clues? Please help!
