Hello everyone.   I am from Australia and purchased CREATION PCUT CT0630 a month ago.  I noticed that the vinyl decals come up a bit undersized.  I use Flexi 10 for programming and I program the decals to be 500 mm O/A Length and 40 mm O/A Width but they end up on the sheet as 499 by 39. The same thing happens with the test cut.   I am using the following parameters:   USB cable as connection port WIN XP SP03 Press: 118 units Speed: 40 units (due to small decal size) Blade 45 deg standard vinyl Blade (1.5 mm shank dia 23 mm length) Knife offset : 0.009 in Flexi 10 Basic version.   The cut is otherwise fine.The blade sticks out of the holder by 0.5 mm.   Please help as this issue is driving me insane.   Regards   SINGH +61426141448 kainth.c.s@gmail.com
