In the continuing saga of my MH871 cutter going down for the count (USB port busted) I decided to bring in a replacement machine, and the LiYu - SC fit the bill, price-wise.
Out of the box, the stand assembled quickly (I had viewed the video) and then my computer required no special install to start cutting (I just changed my SB Cut Setup to LiYu and the machine just hummed right along)
Now, here are some items that are worth mentioning --
1. Even with the blade BARELY poking out of the end of the holder (and I mean, like I need a magnifying glass to even see the point sticking out) I must keep the pressure at 1mm, which is the lowest possible. And even then, I have backing paper being scored.
2. Tracking of long sections of vinyl is pretty dismal, and I'm messing with the pinch rollers to try and correct that. I also experienced that "vinyl bunching" problem at first, but that's been resolved with adjustments of the roller pressure. Just gotta keep on fiddling around until I get it right.
I do like the way these pinch rollers slide smoothly across their tracks (much more easily and fluidly than the MH does)
3. Lord knows, when paying $90 for a stand, getting a catch-basket as a standard attachment would have been nice. But, I'll now have to fabricate one (just as I did for the MH).
4. Much QUIETER than the MH Refine, for sure.
However, it makes this noticeable Tap-Tap-Tap as the blade holder comes into contact with the vinyl (the base is hollow, I guess, and echoes the impact).
5. The machine is white/beige & the base matches. So, why include a BLUE dust cover? It should be white, obviously.
6. In the first day of cutting, it stopped twice. This SC simply decided to quit right in the middle of longer jobs that were running (eight-footers). I have the machine grounded properly, and this really surprised me, as a crash/quit never happened with the MH.
Both times this occured (two different jobs), I rebooted everything (computer and program and machine), resent the work, and the SC proceeded correctly to the end of the cuts.
I'll update this thread with further comments as I go along...
