maverick5754
HELP WITH PLYWOOD SIGN
I have been asked to make a 4'x4' outdoor sign using plywood. Can someone tell me what type of paint (semi glosss, gloss...enamel..etc.) would be best to use to seal the plywood and the vinyl will adhere to best. Also, do I need to use a clear-coat sealer over the finished product to keep the vinyl letters from peeling off, if so,,,what kind is best?....Thanks!
I don't know about letters sticking to the vinyl,the important thing to me would be the paint sticking to the plywood.Otherwise,the vinyl would pull the paint off. When I was in the furniture refinishing biz, I always used acrylic enamel on top of a primer coat.Furniture grade plywood is best.More expensive but better surface. I never sealed over the enamel. I have seen the sealer act as paint remover and ruin the finish.
Thats just my furniture refinishing point of view. I would think that the vinyl would stick just as well to an y nice clean,smooth surface.
Cut the plywwod 4x 4
Sand the Plywood w. rough grit
Paint with Enamal 2 -3 coats
Dry
Apply vinyl
Just did a 30" x 12 feet one just like this it was a two peice seem Sign
Worked perfect
Thanks for that info. So I don't need to apply a clear coat over the vinyl after apllying to prevent weather wear?
Beardown,
I need to get my plywood cut for my outdoor signs tomorrow and get them painted and ready for my vinyl graphics.
Will regular plywood hold up well outdoors ?
When you say enamel - you mean just spray paint?  I had planned on painting them with a few thick coats of paint - brushed on.  I thought if I got some nice exterior latex that I would end up with a pretty smooth fisnish - and if I paint all the edges it should be waterprooof as well.
Am I setting myself up for a disaster?
Thanks.
Dry
Apply vinyl
Worked perfect
I think the best plywood you can get is MDO (medium density overlay). It's got a smooth rasin overlay on one or both sides and is rated for outdoor use. The bad I'm sure its more expensive and harder to find.
More common plywood is labeled with a code like ACX. The first letter is the face, the second letter is the back, and the x is for exterior adhesive.
"A" is the highest grade smooth with no knots, down to "D".
In any case exterior plywood will be damaged and warp when exposed to water so paint all sides and edges.
The word "enamel" simply means the paint will dry to a hard finish and can be applied to almost any type of paint.
Thanks Hobbot,
Yes I'd love to find MDO but you just can't find it here.  So I'm going the smoothest plywood I can find and paint it like crazy.
Is there any clear I can use on top that's safe for the vinyl letters?  I really want to waterproof this thing.
Thanks again,
J.T.
I don't think clear coat over the vinyl is a good idea you might cause more problems. If your worried about longevity 3M has a Edge Sealer check it out I think this is what your looking for.
I would check with the manufacturer of your vinyl, but  am fairly certain that any sealant or protective overcoat will void the mfg. warranty.my supplier sells an edge sealer that works great.
your best objective is to get a good hard smooth  surface to apply your vinyl too.
good luck with your project and post some finished pics.
I use "Frog Juice" to clear coat almost all of my projects. It comes in an aerosol 12 oz spray can, and in my opinion is much more durable than the edge sealer and a lot faster to applicate.
You can find it in the accessories section at www.signoutletstore.com
Okay I'm an idiot - I admit ... do I want the green or pink can of frog juice ?
I'm just using vinyl letters on outdoor oil based paint.
Is there anything I can buy locally that's comparable?  I bought a can of poly to put over the entire sign to help waterproof it but now I'm afraid it will yellow.
Thanks.
The green can is what I use. There's a reason..I can't remember why. It works good though. I would think just a regular clear coat would work...but I've never tried it.
I know this is a late post, but MDO is what sign painters used for years.  You can buy it from Menards in a good 1-side or good 2-side.
instead of buying plywood get some medium density fiberboard, its very cheap and handles the outdoors well, prime it than paint it a few times than apply your vinyl
egg
egg
Actually MDF is not really suitable for outdoor aplications unless you are in a very dry climate, we used it quite often in Las Vegas but anywhere there is alot of rain, sprinlkers, or humidity and it will swell to 3 times its size and fail. You could however use MEDEX which is a medium density fiberboard for EXterior applications.
The real problem with MEDEX it is is almost as expensive as MDO and weighs much more.
