Guest Ginny Posted October 28 When I go to cut a design, everything seems ok until I click Cut Now. After clicking it, VinylMaster hangs or lags for anywhere from 10-60 seconds before it continues. Then, after the cut finishes, when I click Done, it hangs or lags again for 10-60 seconds. This is making the cutting process frustrating because of the long delays before and after each cut. Has anyone else experienced this issue? Does anyone know what might cause these delays before and after each cut? USCutter Tech Support suggested using a 2.0 hub to connect the cutter to my computer instead of the 3.0 hub it was connected to. I have used this cutter with this computer for at least 3 years. Nothing has changed. Any help would be appreciated! Quote Share this post Link to post Share on other sites
haumana 1,232 Posted October 30 how far is the cutter to the computer? what version of windows are you running? did your computer do an update? if you're using a usb hub, is it's active (external power) or passive (no external power)? It's best to connect the cutter to the computer directly instead of using a hub (I know that isn't always possible). have you tried replacing the usb cable? I had a cable fail on my cutter, and it made me crazy trying to troubleshoot it. you can try to change the cable. 1 Quote Share this post Link to post Share on other sites
midwestmomm 3 Posted November 3 Thank you so much for replying! I really appreciate the help! Just to clarify, I'm the original poster, Guest Ginny! I finally managed to get logged into my old account, so I'm now posting as midwestmomm. My cutter is less than 3 feet from my computer and has been in the same setup for 3–4 years. I've tried different USB ports, replaced the cable previously, and switched from direct USB 3.0 to a USB 2.0 hub (without external power) at USCutter Support's recommendation. No improvement. Windows updates automatically, so I'll check the update history. I've also been working with Future Corporation, the VinylMaster developer in Australia, but the overnight replies make troubleshooting painfully slow! They've had me remove a duplicate/inactive SAGA cutter device in Device Manager, disable USB power-saving settings, and restart Windows. The first few cuts improved, but the delays quickly returned. Future suspects something accumulating on the computer during cutting sessions rather than a USB connection issue. The Vinyl Spooler now opens completely blank for 60+ seconds before I can click Cut Now, and sometimes freezes after clicking Done, requiring me to force-close it. I'm getting desperate! LOL! I have a ton of signs to finish before my holiday closure. Any other suggestions would be GREATLY appreciated! I'm willing to try just about anything! Quote Share this post Link to post Share on other sites
midwestmomm 3 Posted November 3 I'm running Windows 11. I checked my update history and found that Windows installed several updates on October 14, including a Hewlett-Packard USB driver update. Could that USB driver update be related? If so, is there a safe way to test or reverse it? I'd appreciate any suggestions! Quote Share this post Link to post Share on other sites
