Cutter guy 0 Posted October 6 (edited) Hello people, I have a Desay Master Tiger 1000 48 inch cutter that I bought back in 2009. It works like new. Still on the first blade! Having a software issue but its not the software, its the dongle key. It worked great up to about 2 months ago, and now win7 sees the key, but the program doesnt. I removed and reinstalled signgo fd. Still no luck. Downloaded an early version of the trial, it works great. BUT, only for 30 days. I tried contacting the companies that used to sell the software in the UK but they told me that there is no longer any support or key or serial number that is available to get me back up and running. Does anyone out there have a workaround? Key, serial, crack, anything? I tried easy cut 5 and it didnt really work well on my cutter and didn't even have the exact driver. Ive been trying to find siftware that works with 32 bit win xp or 7 but no luck. There is a program that is open gl but to add the cutter in requires python and then the cutter program. Ive been out of the IT circle for 20 years and find this to be overwhelming. Any help would be greatly appreciated. Edited October 6 by Cutter guy Type Errors Share this post Link to post Share on other sites
MZ SKEETER 4,728 Posted October 7 You haven't stated the brand name of the dongle. Flexi software dongles have a brand name on them. Then you can go to their website and reinstall the driver for the dongle. Share this post Link to post Share on other sites
Cutter guy 0 Posted October 8 You haven't stated the brand name of the dongle. Flexi software dongles have a brand name on them. Then you can go to their website and reinstall the driver for the dongle. It says master on the USB dongle. I have no clue wherevto go actually. The 2 UK companies that took over Signgo told me that the software is obsolete. Its odd because as a workaround, I was able to download a copy of signgo with a monthly trial. But that wont help me after 1 month. Share this post Link to post Share on other sites
Cutter guy 0 Posted October 8 You haven't stated the brand name of the dongle. Flexi software dongles have a brand name on them. Then you can go to their website and reinstall the driver for the dongle. The dongle is not accessible by any means. Windows sees it but there are no files visible. I dont think there was anything readable on it. Share this post Link to post Share on other sites
haumana 1,232 Posted October 8 There was something initially readable on it, but readable by the SignGo application. What happened between the time it worked, and the when it didn't? Did you install something new - hardware or software? Did anything update? It sounds like there's a chance that the file on the dongle got corrupted. Unfortunately, if that's the case, there's really not much you can do about it, besides finding a different program to move on to. Have you tried SignBlazer Elements? Yes, it's considered abandonware because the creator passed away some time ago, but it's a solid cutting program, and one that I usually recommend when people need to test something out with their setup. I can't say if they have the exact driver in SignBlazer to support your cutter, but there might be a rebranded/generic model in their list that's compatible with your cutter. Share this post Link to post Share on other sites
Cutter guy 0 Posted October 11 There was something initially readable on it, but readable by the SignGo application. What happened between the time it worked, and the when it didn't? Did you install something new - hardware or software? Did anything update? It sounds like there's a chance that the file on the dongle got corrupted. Unfortunately, if that's the case, there's really not much you can do about it, besides finding a different program to move on to. Have you tried SignBlazer Elements? Yes, it's considered abandonware because the creator passed away some time ago, but it's a solid cutting program, and one that I usually recommend when people need to test something out with their setup. I can't say if they have the exact driver in SignBlazer to support your cutter, but there might be a rebranded/generic model in their list that's compatible with your cutter. Nothing new installed. It's definitely corrupted. I can see the drive. It used to have the installation software on it, and the serial coded info. I cannot see its contents. I did make a copy of that stuff years ago but I tried copying it to a flash drive and that didnt work. The signgo program is looking for that specific dongle key info. Anyhow, Im partial to this signgo program because i have a very old desay master tiger 1000 cutter and it worked great with it. I haven't tried signblazer yet. Not sure where to find any of these other programs. I have a ton of files I've created over the years with signgo and they are WTP files. I dont know what other cutter software recognizes these so signgo is crucial for me. I contacted a vendor of the signgo trial download and they said the company went out of business, and there own company no longer support it, I should try wissen UK. The software trial download was still out there surprisingly. I was able to find the 30 day trial of it. Again, no support, and yet they still offer it for download and when you go to pay its blocked because it forwards you to the website which is 404'd. I do have the working downloaded trial now, so that at least got me out of a jam. I have plenty of spare 40gb sata drives that I could reformat and Im thinking if I reinstall windows 7 on one of my drives but remove the motherboard clock battery, I would have to manually set the time and date each time in bios prior to windows booting into its virtual machine mode. With my spare drives, I think I could create a master drive just to keep the trial download on. Then, I'm thinking that I could reinstall it when I need it onto a reinstalled windows 7 if windows doesnt have a timestamp. I rarely use signgo nowadays, but every now and then, I need it. Do you think my Idea might work to trick the signgo trial to stop counting down the days? Share this post Link to post Share on other sites
haumana 1,232 Posted October 12 Going to be honest, any copy of the dongle is not going to work, it's designed that way. You probably will not find anyone that has a copy to spare, or a legit dongle for it since it's abandonware already. If you're really married to the software, then you'll have to resign yourself to uninstalling/reinstalling the trial version on a regular basis. I'm guessing that your files are saved in a propriety file format, so you might want to start backing-up/exporting your graphics files into more universally compatible formats like .svg or .eps. I completely understand about not wanting to change software, I am absolutely the same way. It was painful for me to relearn something I already knew how to do in SignBlazer, then had to learn Graphtec Pro Studio because I chose to switch from Windows to Mac. Honestly, I still hate it, but I use my Mac more than I'm using that software, so that's the trade. Just saying that you might need to inevitably need to make some kind of switch, and SignBlazer is a free way to go, or you can take a look at the other paid software out there - VinylMaster, Sure Cuts a Lot, etc. At least those two companies are still around, and don't look like they will be going anywhere soon. Share this post Link to post Share on other sites
Cutter guy 0 Posted October 12 Thanks. I was able to find signblazer in an archived that a member put on this forum so I appreciate all the help. Im not sure if uninstalling and reinstalling will work but around the final few days of it, I'll give the uninstall/reinstall a try. If not, I'll see if the clock battety trick works then the hard drive trick. If I csn save my wpt files to ai or eps, id be stoked Thanks! Share this post Link to post Share on other sites
Cutter guy 0 Posted October 21 Going to be honest, any copy of the dongle is not going to work, it's designed that way. You probably will not find anyone that has a copy to spare, or a legit dongle for it since it's abandonware already. If you're really married to the software, then you'll have to resign yourself to uninstalling/reinstalling the trial version on a regular basis. I'm guessing that your files are saved in a propriety file format, so you might want to start backing-up/exporting your graphics files into more universally compatible formats like .svg or .eps. I completely understand about not wanting to change software, I am absolutely the same way. It was painful for me to relearn something I already knew how to do in SignBlazer, then had to learn Graphtec Pro Studio because I chose to switch from Windows to Mac. Honestly, I still hate it, but I use my Mac more than I'm using that software, so that's the trade. Just saying that you might need to inevitably need to make some kind of switch, and SignBlazer is a free way to go, or you can take a look at the other paid software out there - VinylMaster, Sure Cuts a Lot, etc. At least those two companies are still around, and don't look like they will be going anywhere soon. Ok so as a FYI, I tried uninstalling the trial then reinstalling it and it came back where it left off so it didnt restart its count down. But,,,I was able to take a backup of my hardrive which was a clean windows 7 drive, no additional software, and clone it using minitool. I then copied over the teial executable. Installed it and got a day 1 again. I now have a clone that has never had signgo on it. Using minitool, I zero filled the other drive, formatted it cloned it again cipied over the executable, waited a few says and then installed the program. It works. As long as I can get enough time to export my WTP files into EPS files, then I can get all my drawings vonverted for signblazer and be done with signgo for good Share this post Link to post Share on other sites
darcshadow 1,643 Posted October 21 Hard lesson to learn but keeping files in open formats what possible is always a good idea. This is never stressed enough to people starting out. Share this post Link to post Share on other sites
