Tambo
Did I make a buyers mistake
I bought a very nice US Cutter MH721-Mk2 thinking there would be software out there. I am using a USB cable, and I keep seeing different people talking about using that cable.
Did I make a mistake buying this??? It didn't come with the software, I have a Cricut, so I just don't know whether to resell this or is there some way to make this work with windows??
Please someone help me.......
Before you throw in the towel - I would suggest that you download Sign Blazer Elements, and give that a try.  You can find it it a link to it here.  Just a few things to know ... The original creator of Sign Blazer Elements (SBE) has long since passed away, and the only support is places like this forum.  Cutters are simple machines, and the technology to make them work doesn't require much, but the software that user's "see" have improved greatly over the years.   You might need to disable the antivirus on your computer to install SBE, as one of our forum member has managed to 'patch' it so that it you ca run the program beyond the trial period.  There is no virus, it's the patch gets flagged.  SBE looks like a very basic program, and is fairly basic, however, it's a workhorse and many users cut their teeth learning on it.  It's also one of the "go to" programs when people are trying to troubleshoot their cutters and/or files.
The cutter will not install like a printer, or scanner, or any device that's readily available in Windows.  However, the main to know is that the COM Port your windows machine assigned to the cutter needs to be 4 or below, and that it needs to match that number in cutting software too.  If you need to know how to check and/or change the COM Port number, there are several post in this forum that can walk you through it.
I would help us if you let us know which version of Windows you are trying to get the cutter working with.
+1 for signblazer, great starting program. It works wonderfully for laying out designs and has a nice library of images. It is a bit limited for creating images from scratch. I use a free program called Inckscape to do my designs in then used Signblazer to send to the cutter.
