siru
which plugging i can use this cutting plotter
 Name brand and model is right on the plate.  ( 2nd of your photo) it is a ROHS 721 vinyl cutter.
I think that RoHS is the Restriction of Hazardous Substances marking not the make. Not to say it could happen to also be the make.
Siru, are you needing the drivers or just curious about the make. If it has a USB port, a generic FTDI driver will probably work. If it has a serial port, you don't need a driver, set correctly configured software, and a serial port on the computer.
If you want to know how to connect it, it would helpful to see a picture of where the connection ports are, and what platform of computer you plan on connecting to it (ie. PC or Mac).
If you put "Rohs" in the upper right search bar,  Rohs comes up for many other threads, so not sure. Some are  saying Rohs  is the make of their vinyl cutter.
