Good day. I've used this vinyl cutter for almost 15 years. Straight USB from my PC to the cutter using Flexi 8.6v2.
The USB type B port on the plotter has stopped working. I've noticed it's a bit loose and it will work if i take the cover off of the end of the plotter and hold the actual port and the cable as I hit send. The data is transferred and it cuts. This is not a long term solution and the IO board is no longer available to purchase. The  cutter does have a serial port. After reading through the forums, I purchased a Tripp-lite Keyspan adapter as well as a null modem serial cable and connected them from my PC to the cutter in this order. USB cable from PC to Keyspan to null modem cable to cutter. I've made sure the com ports in device manager and production manager match, currently COM2. When I hit send, it says "cutting  0%" and never goes higher. The cutter does nothing and eventually production manager throws a write port error. What can be the issue? Hoping this can be resolved without soldering a new usb port onto the board or buying a new cutter. One thing to note, the face of the cutter says TC series but production manager doesn't give the option when adding a setup, so I've always used SC series in place and it's always worked.
Have you taken a look at this thread?  Other's have discussed the same error that you were getting.
The only thing that I would recommend it unplug the keyspan from your computer, reboot, and plugging the keyspan in a different USB port, reassign the COM port number if it's higher than a 4, and change it in Flexi too.  I'm guessing that you did install whatever necessary driver for the keyspan.
What version of Windows are you on?
The vinyl cutter is NOT a US CUTTER Liyu SC vinyl cutter.  It is a US CUTTER Liyu TC vinyl cutter.  It states it right on the vinyl cutter on the control panel.  MODEL TC PLOTTER. Now whether that will make a difference in the cutting software driver, you will have to change everything and check.  I don't think forum user Monkey ever got his Liyu SC to work with a Tripplite Keyspan adapter.
The official baud rate for the Liyu TC series cutting plotter is 19200, as specified in the manufacturer's user manual. If you are using software configuration or troubleshooting a serial COM port connection where 19200 does not respond, 9600 or 57600 are alternative rates occasionally used depending on your driver or software bridge.
https://uscutter.com/content/PDFs/tc_manual.pdf?srsltid=AfmBOoofiBcLRJdsaWxbOZ6YgPXu3j3HXI52M3FH81C4kFSyt8-lWXiH
Thank you for the replies. I will read through the thread offered by haumana as I'm unsure I've seen that one before.
I'm using Windows 7 Home Premium.
I realize that this is a TC series, but my version of Flexi does not offer TC under the Liyu brand when setting up a new cutter. It has worked though the USB connection for many years with SC selected. Baud rate has always been set at 9600, but maybe with the serial adapter I need to change to one of the other rates you suggested.
Also, thank you for posting the TC user manual.
I will report back when I've had a minute to investigate more.
Thank You
Well, I changed the baud rates to the suggestions above and same result.
Also tried changing ports and connecting the keyspan while the computer is off, then starting, same result.
I think I'm about out of things to try.
Opening the cover to manually hold the usb type b port on the board, inserting the cable and hitting send all the while hoping it doesn't lose connection until all the data is received isn't a long term viable solution. Might have to 'office space' it.
Out of curiosity, are you able to do a test cut directly from the cutter's control panel?
When you send the job to the cutter, does the control panel display change at all?
Was there a recent power outage and/or windows update?
Maybe try dumping the existing driver for the keyspan, and reinstall it.
I'm not sure that model board will work. Mine looks like the one below.
I'm also unsure what type of connection the top right connector is. It accepts a ribbon cable. Do you know if this is just a low insertion / friction fit cable that just pulls out and pushes in? I can't recall. It's been about 10 years since I changed this board.
The machine will do a test cut straight from the panel. It works fine with the USB type b port when i can hold it all steady enough to transfer data. The problem is, it only maintains connection for a few seconds, plus I have to take the end cover off to do this.
The control panel on the cutter does not change when sending to the cutter. Production Manager stays at "cutting 0%" and then eventually 'write port error'. No windows updates and no power outages or surges I'm aware of. I did try uninstalling and reinstalling the keyspan driver.
I've been able to make due using the method described above. The image below is from Alibaba.
https://www.alibaba.com/product-detail/Cutting-printer-plotter-Liyu-TC-USB_1600589564857.html
I haven't had good luck ordering from them in the past but they may be my only option. My best bet may be to find someone to solder a new USB type b port to the board.
Thank you both for your help. Any other suggestions are welcome.
You could try an electronics repair shop who specializes in board repair in your area. Depending on price.
Finally a solution. I took it to an electronics repair shop to replace the USB type B port.
$24 total and about 20 minutes of my time.
Thanks for your timely responses and suggestions.
