diltech 0 Posted August 16, 2024 Hi, I have two cutter. FC8600 and FCX2000 since a few time. When i set my cut on FCX2000, it is very slower than my FC8600 for same speed (40cm/s). For cutting circle, the speed it's more slower too. What wrong on my config ? Thank Share this post Link to post Share on other sites
MZ SKEETER 4,728 Posted August 16, 2024 It does not matter what you have the speed value at on the machine. You must compare the cutter specs to each machine. They are not the same machines, nor do they have the same boards in them or the same specs. Compare to the specs of this Graphtec FC8600 at 1485mm Max. cutting speed 4 ft 10.46 in/s (1485 mm/s) at 45° direction You cannot make a vinyl cutter run faster than it is designed/manufactured to cut. Model name FCX2000-120VC Mountable media (Y-axis) 950mm Roll media support Roll media stocker (manual feeding), supported media; width: up to 950 mm, weight: up to 5 kg Maximum cutting speed 400 mm/s (1 to 40 cm/s in 16 steps), in all directions Cutting force Tool 1: Max. 4.9 N (500 gf), Tool 2: Max. 9.8 N (1 kgf) Share this post Link to post Share on other sites
slice&dice 2,471 Posted August 16, 2024 400mm is the max speed? I'm looking at my Chinese (copy of the graphtec) LiYu/SC2, with a stepper motor, and it's max at 800mm. But, there's another Max speed indicated above -- 1485 mm/s -- is that a keypad setting? Or does the keypad go up only to 400? Share this post Link to post Share on other sites
MZ SKEETER 4,728 Posted August 17, 2024 400mm is the max speed? I'm looking at my Chinese (copy of the graphtec) LiYu/SC2, with a stepper motor, and it's max at 800mm. But, there's another Max speed indicated above -- 1485 mm/s -- is that a keypad setting? Or does the keypad go up only to 400? The 1485 mm that I posted above, is for the Graphtec FC8600. That is why the flatbed is so much slower. Here is the spec sheet right from Graphtec. https://www.graphtecamerica.com/fcx2000 The Graphtec FC8600 = 1485 mm vs 400 mm= FCX2000 (MAX CUTTING SPEEDS) Share this post Link to post Share on other sites
diltech 0 Posted August 19, 2024 Thank you for this explanation, I really thought it was me who had misconfigured the machine. I am very disappointed with this poor performance for flat cutting. I think the specifications should be clearer when purchasing. Greetings, Share this post Link to post Share on other sites
