James159 0 Posted January 21, 2024 So far I can only run this on Windows 10 Cutting Master 2 2.00 Works Graphtec Studio 2.2.1252gs does not connect. Can export file as PLT to Cutting Master 2 2.00 then it prints (but how do I set the sizes for the images or text?) Any youtube I can follow. can use Adobe Illustrator 2020 Might need to boot my windows 7 for this machine or separate os running with windows 10 Share this post Link to post Share on other sites
James159 0 Posted January 21, 2024 Seem like only Illustrator CS3 works so it lets you covert the files to use on Graphtec Studio then to Cutting Master 2 2.00 Share this post Link to post Share on other sites
darcshadow 1,642 Posted January 23, 2024 Can cutting master 2 not open eps or svg files? Why are you converting to a graphtec studio then then to a cutting master file? You should be able to use what ever design program you like then save the file as an EPS or SVG file and then import that file to your cutting software. 1 Share this post Link to post Share on other sites
James159 0 Posted January 23, 2024 there are soo many software out there which free software can i use? cutting software 2.0 only allowing .JOB .PRT and .PLT files type What software can I use for design and text design for CE500-60 Share this post Link to post Share on other sites
MZ SKEETER 4,728 Posted January 23, 2024 Good design and cutting software with updates is NOT free.. There are people who use Signblazer, which is an unlimited trial. For Windows.. It has not been updated for probably 10 years. I do not use it. You have to choose a software that is compatible with your computer operating system AND your vinyl cutter. The Graphtec site tells you what is compatible if choosing Graphtec software. You can purchase, VinylMaster, Sure cuts alot, Signcut, Flexi software. And some others if you search. You can also purchase design software. Or Inkscape.org is FREE design. This is considered a skilled job, that you may need to invest some money into, to get the results that you are seeking. Share this post Link to post Share on other sites
darcshadow 1,642 Posted January 23, 2024 I would be very surprised if Cutting Master can not open or import and EPS file. If you don't see EPS as an option when you select open, look for an import option. You can design for any cutter in any design software. Just like you can print any picture with any printer, you can cut any design with any cutter. I like Inkscape for design. It's amazingly powerful for a free program. Pick your design software, make your design, save it as an eps file, IMPORT the eps file into your cutting software, click cut. Share this post Link to post Share on other sites
