Levauto 0 Posted May 11 I have a problem with a Creation CT630H. I instalad Sigh Blazer, and configure the cutter port as Xon/Xoff control, 34800 bauds. The cutter start the job, but don't do all the cuts, it let some parts uncutted, doesn't matter what to cut, I got letters uncuted on a simple word of text, and from time to time the head goes top left and keep there until I turn off and on again.I tried different baudrates and control, but then the head just don't move... can anybody put me in the right direcction to find the problem, please? THANKS Share this post Link to post Share on other sites
slice&dice 2,426 Posted May 12 Set it for 9600 baud and Flow Control to 'hardware' and make sure you have the correct COM port configured. Are you using USB or Serial cable? Share this post Link to post Share on other sites
Levauto 0 Posted May 12 Set it for 9600 baud and Flow Control to 'hardware' and make sure you have the correct COM port configured. Are you using USB or Serial cable? First, THANKS for your answer... I am using USB. WIth 9600 baud and flow control set to hard, it roll out the vinyl, and never start to cut... Share this post Link to post Share on other sites
slice&dice 2,426 Posted May 12 The first thing I would do is uninstall and reinstall SBE, using this link: (bad link removed -- scroll down to my next post to see a working download host) Secondly, does the cutter perform the self-test cut correctly? (using the TEST function on the keypad). In the opening posting, you indicated the cutter head does move and cut some of the job, but intermittently. (with the baud high and the flow to x) Now, with what should be the correct setting at 9600 and hardware, you say it doesn't move. This seems to indicate a circuitry failure of some sort in the motherboard, which is not something we can troubleshoot. Or, it's even possible the USB cable itself isn't properly transferring data. Do you have an option to switch over to Serial (RS232)? Share this post Link to post Share on other sites
Levauto 0 Posted May 12 I can't reinstall sb with the the exe on this link, I get "failed to read setup engine" error message . Self-test works fine, cuts a perfect rectangle...the cutter worked fine, my problem started when I changed to a new laptop with Windows 11. because the old pc I was using with old windows and Flexi 10 died suddenly... rest in pieces With the new laptop I am trying Sign Blazer and Artcut 2009... both have problems depending on how I configure the port, so, I think this must be the problem, and I don't remember my old port configuration. I lost Flexi software when the old pc die. I am sure there is no hardware problem, all was working fine with old pc. I tried with different usb cables, with the same result, and this new laptop have no RS232 port. I emailed Creation two weeks ago, asking for the right configuration, bur they don¡t answered me yet Thanks again for your help Share this post Link to post Share on other sites
slice&dice 2,426 Posted May 12 Dang, you are right about that version of SBE installer on ButtonTaylor server, something is not right with it, unfortunately. Finding a good copy of SignBlazer installer is nearly impossible these days. USCUTTER discontinued hosting it on their site (archives) and most of the other links all over the internet are broken. I did create access on MediaFire at https://www.mediafire.com/file/fjk69hgu2cpnr16/signblazer_setup.exe/file However, I doubt the problem is with the program, and tend to agree you have something happening with the port config. Share this post Link to post Share on other sites
Levauto 0 Posted May 12 Thanks for the file. I think maybe is the driver... I installed the FTDI driver from the website, but maybe the specific creation CT630H usb to com driver is needed... I will email them again, because I can't find the original CD and there is no download links in Creation web... Share this post Link to post Share on other sites
slice&dice 2,426 Posted May 13 I have had tremendous luck with the following Virtual Com Port, maybe give it a try? http://kiss.flyduino.net/download/stm32-virtual-com-drivers-64bit-pc Share this post Link to post Share on other sites
