Guest Bryan Posted February 11, 2023 I am trying to figure out how to cut layered images without cutting the left over image. I have a solid image that I layered with a "distressed" image. The distressed image is much larger than the solid image however I only want to cut the original image thtmat contains the portion of distressed image directly on top of it. I tried to contour cut and also tried to find a way to crop it with no luck. Any help would be appreciated. Quote Share this post Link to post Share on other sites
haumana 1,220 Posted February 11, 2023 I am trying to figure out how to cut layered images without cutting the left over image. I have a solid image that I layered with a "distressed" image. The distressed image is much larger than the solid image however I only want to cut the original image that contains the portion of distressed image directly on top of it. I tried to contour cut and also tried to find a way to crop it with no luck. Any help would be appreciated. Aloha e Bryan. Welcome to the forum. It's super quick, easy, and free! I would suggest you register as a forum member, that way your post show up immediately, and it won't be delayed waiting for one of the volunteer moderators to approve your post. Now on to your original question, this video might help you or at least point you in the right direction. 1 Quote Share this post Link to post Share on other sites
