MrsYee
Changing layout cut sequence
When I send my design to the cutter and choose to cut 6 items, it shows exactly how I want the cut to proceed (Layout 1).  When I select "Cut now", the  Vinyl Spooler screen pops up with a different layout (Layout 2).  I do not want it cut in this layout, but in the original layout.  Why is the software changing the layout?
Sometimes you have to make sure that both media width sizes are the same on both windows. On your vinyl spooler click on cut options and make sure your media width is the same 20" as previous window.
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
