Hen 3 Posted December 12, 2022 I have saved a lot of my work and when I go back to use it later it will not open. I try file-open and I see them but they have a blue box and the blade instead of just the little blade in the corner. When I try to open them they just go to the blank grey screen as if I didn't try to open anything. The ones with the littler blade at the bottom, opens up just fine just not these. Tried open-import-file it doesn't do anything but goes back to the grey screen. Quote Share this post Link to post Share on other sites
darcshadow 1,626 Posted December 12, 2022 What is the file extension of the files you're trying to open? If the icon is different from what you're expecting you've probably saved them in a different file format. How did you save them? Quote Share this post Link to post Share on other sites
Hen 3 Posted December 19, 2022 The file type is vinylmasteruscdocument(*.vDoc). When I save it's the only option that I am seeing. Quote Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted December 19, 2022 Does your vinylmaster software, have file>export .eps? Eps files can be used in many more soft wares. Quote Share this post Link to post Share on other sites
Hen 3 Posted December 19, 2022 When I try to use the file>export it gives me all kinds of different ways to save it. I have never tried saving it that way, only by saving it by file>save Quote Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted December 19, 2022 Well, try it. Isn't .eps on the drop down list? The only place that you can use those v.doc files is Vinyl Master. .Eps files can be used in a lot of different cutting soft wares. You shouldn't limit your files to one file format. If you needed to post a file, or try a v.doc on other software, you won't be able to do it. There, a lot of of us, that do not have Vinyl Master software, and we couldn't help you with it. But most of us can import .eps files with our different cutting soft wares. Quote Share this post Link to post Share on other sites
