Dan Marquis 0 Posted November 4, 2022 I have a CX-300 I have been using for years. Suddenly it will no longer cut. I use CorelDraw, and when I click the cut button, the graphic blinks as if it were going to cut, but the plotter does nothing. I've tried shutting off the program, the plotter, and the computer... even tried unplugging the plotter, but not helps. Even tried using an earlier version of Corel to no avail. Any suggestions? Dan Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted November 4, 2022 No mention of trying a different cable or a different cutting software. There are free trial cutting software you could try. Or whether the cutter, even cuts the TEST feature, directly from your cutter.. Or which version of a computer operating system that you are using. Or whether a update on your computer is causing problems. Like trying system restore to go back when it did cut good. Is Coreldraw being used with a Roland plug in, as CorelDraw is not cutting software. Have you reinstalled the drivers? Share this post Link to post Share on other sites
