rhenda 0 Posted January 31, 2022 I trying sublimation for the first time I have followed everything on the web to do to start. Using a epson et-2760 printer converted the printer to sublimation printer with sublimation ink. Changed my the setting for the printer. I’m using A-sub sublimation paper. My press is a circuit press. I use a circuit t shirt. I can put ink on the paper with my finger it works. When I try from the print from the computer it want transfer. Any idea what I’m doing wrong thanks. Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted January 31, 2022 not exactly sure what you are saying in your post - the printer doesn't deposit ink on the paper? if so a printer problem - or the printed image won't transfer to the shirt? if the second I am not familiar enough with a cricuit press but doubt it would hit the 400 degrees necessary for sublimation ink to turn to gas. second is the shirt needs to be 100 percent polyester, 50/50 shirts will transfer ink to the poly portion of the shirt and give a distressed look. sublimation paper also has a right and wrong side - usually the right side is a slightly brighter white Share this post Link to post Share on other sites
rhenda 0 Posted February 1, 2022 The transfer will not come off the sublimation paper. Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted February 1, 2022 the ink has to reach around 400 degrees to turn to a gas and attach to a polyester surface - if the press is not capable of reaching 4000 degrees the ink will not turn to a gas so no transfer will happen Share this post Link to post Share on other sites
