Damon Pence
"Auto Start" in the Cutting Module
Hello, looking for this answer but other than the help file I have not found any information on my question.
In the Automark Cutting Module, there is an option at the bottom left to check for "Auto Start".  Giving the ability to start the contour cut from the cutter by hitting the speed key on the cutter.  However when I check the box a message comes up "polling cutter, press speed button to start", I set up my cut to the correct point and hit speed up or speed down arrows and nothing happens.  Is my current cutter not compatible with this option?  Me being me, I have tried EVERY button on the cutter just to make sure I didn't miss something.
Cutter: Titan3 w/Arms
software: VinylMaster Pro v4.2
thanks,
Damon
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
