newtothis 0 Posted November 16, 2021 Hello everyone, I just purchased a Laser point 3 with arms and Vinylmaster pro. I can't figure out contour cutting/ print and cut. I have tried to calibrate my cutter using the Vinylmaster software and nothing. The blade doesn't move when I try to adjust the on-screen offset controls in calibration. So far I have not had a successful ARMS calibration with pen tool yet. I've watched multiple videos and some how when I print things the cutter still isn't reading the registration marks properly. I have tried repositioning my material on top of the registration marks, just inside the marks and just outside the marks and it still isn't cutting right. At this point I'm uncertain if I'm positioning my material wrong or not and I don't know how to calibrate my cutter so that when I print images on heat transfer paper, the blade will cut precisely on the contour lines outline on-screen. If ANYONE has had these problems please HELP! Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted November 16, 2021 Are you following all of the instructions on this video? If you are, then contact USCUTTER tech support. Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted November 17, 2021 make sure in your artwork you create a vector contour line for the plotter to follow - I haven't done it in VM but this is a pretty universal step - you need that vector line to contour to 1 Share this post Link to post Share on other sites
Wildgoose 4,200 Posted November 17, 2021 Have you cut or plotted ANYTHING? If you haven't I would be sure to play around with basic operation and make sure everything is working correctly before heading into the much more complicated world of countour cutting. 1 Share this post Link to post Share on other sites
