The Flaming Eyeball
Card stock to make gift boxes
I searched the threads, but didn't see anything on this. I have an SC2 and I want to make custom sized boxes for gifts. first, can I do this on my SC2. Second are there templates or patterns available somewhere? Thanks for the assist.
Maybe. First off you will need a carrier for the card stock or you will not be able to without destroying your cutting strip and trashing your cutter when the pieces start to lift. Second, depending on the thickness, and if you have the pressure to actually cut the stock, you will go through blades like crazy.
I have seen templates on line, but can not remember what the site was. Goggle should help with that.
Making your own gift boxes? With an inexpensive Chinese vinyl cutter? Sounds nuts.
https://www.uline.com/Grp_97/Retail-Boxes
and
https://www.uline.com/BL_5602/Gift-Boxes
All things considered, this seems like something you should reconsider doing yourself, and just order from suppliers who have the inventory and the expertise to provide what you need.
