dms0088 0 Posted September 30, 2021 extremely new to this we use this plotter to make templates for counter tops we just hooked 3 new computers to the plotter and now it will not cut images deep enough we use color coded plotting we are using the same color as before and no setting have been changed on the plotter itself any ideas why it is now only marking and not cutting through the plastic Share this post Link to post Share on other sites
darcshadow 1,626 Posted September 30, 2021 Have you check the blade? They do wear out after awhile. Share this post Link to post Share on other sites
slice&dice 2,450 Posted September 30, 2021 Are you using THIS material? If not, you probably should be. Share this post Link to post Share on other sites
