Tovar
Help Identifying Vinyl Cutter
Hello everyone! I am looking for help to identify this Vinyl Cutter that I have. I will attach a few pictures of it. Thanks in advance!
It's a standard Chinese cutter, you can run it with SignBlazer and USB (if you don't have a cable with it, any regular printer usb cable will work). Choose Liyu or RedSail in cutter setup, and you should be good to go.
What's the "Leave" button on the control panel do? That what you press when you're fed up and done for the day? ha
  • Haha 2
I wonder if the O-P was trying to just get his unidentified machine to run,  or was seeking info on the functions?
The settings (red button) would not be pressed in general, no need for it in regular operations.
"Leave" is essentially "Offline" ---- to adjust the x & y axis movement with the arrow/directionsl keys and place the vinyl and carriage head in position (then hit "Origin" to set).
I would run up the speed to max (up arrow) which is likely 800. ---- I never reduce speed from max, let 'er rip!
The force is dependent on the media/vinyl, and if the blade is properly adjusted, a test cut will determine what exactly to adjust this value at (90 might be a better starting point).
By the way, it's a VEVOR branded unit.
Good to know about the "Leave" button.
It looks like a chinese imitation of a vevor branded cutter
And if you use the serial connection you don't need drivers for the cutter.
