Hornnumb2 2 Posted May 2, 2021 Store bought or make your own? Thanks Share this post Link to post Share on other sites
slice&dice 2,471 Posted May 3, 2021 Only use RapidTac2 --- great product, especially in winter applications. ActionTac is also fine, in normal temps. Share this post Link to post Share on other sites
haumana 1,229 Posted May 3, 2021 I usually use water, isopropyl alcohol, and a drop or two of dish soap. Easy peasy. Share this post Link to post Share on other sites
VinylM 0 Posted June 28, 2021 @haumana would you mind sharing how much water to how much alcohol? And is it 70% alcohol? Share this post Link to post Share on other sites
haumana 1,229 Posted June 28, 2021 2 hours ago, VinylM said: @haumana would you mind sharing how much water to how much alcohol? And is it 70% alcohol? I use a 1:1 for alcohol & water - 70% of alcohol really doesn't make a difference to me, so whatever you have on hand will work, or if you're trying to save the 91% for COVID purposes, the 70% will work just fine. Then depending on the how much you're make a drop or two of dish soap - like literally a drop. I typically make mine in a 32oz spray bottle, but only do something like: 12oz water, distill if I have it - it's not a requirement, but sometimes I can get some calcium sediment from my municipal tap 12oz alcohol 1 or 2 drops of dish soap - if I'm using Dawn, then 1, if I'm using anything else, then 2. HTH. Share this post Link to post Share on other sites
