TracyB45 0 Posted March 28, 2021 Liyu 631E the buttons on the keypad do not make the cutter work Pressing them has no effect at all on the movement of the carriage or the on screen words, it just dead. It switches on and the screen shows my last cut instructions, SPD 200mm/s PRS: 104g LOCAL TEST COPY. The buttons do nothing except the RESET and that changes the screen to THANK YOU FOR USING THE CUTTER! I have to turn it off to get back to the original screen but nothing happens. The motor is running. I am using Make the cut software and it was working perfect last time I used it, quite a while ago. It sits in my workshop with its cover on and has had minimal use. It was great when it worked Share this post Link to post Share on other sites
slice&dice 2,450 Posted March 28, 2021 Replace the keypad. At this point the only option you have is to disassemble the cutter to access that control panel. Share this post Link to post Share on other sites
