Harley Boyz Ken 0 Posted March 15, 2021 anyone Here works on the Cutters in the Quad Cities trying to get mine set up ? i have a 781 MK2 . Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted March 15, 2021 It's not rocket science, what's your problem? What are you having a problem with? Which step are you, for setting it up? Which cutting software. Which computer operating system? How connected? Share this post Link to post Share on other sites
Harley Boyz Ken 0 Posted March 15, 2021 cutting the project it's just drawing squiggly lines with the pin when i send something to cut. Vinyl Master Cut Windows 10 on a pc Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted March 15, 2021 Is your design a vector design? A vinyl cutter only cuts vector designs. Outlines made up of nodes. Post the file if not copyrighted. Do the com port numbers match in your computer device manager and Vinyl Master software? (only between 1-4) nothing higher. Does the TEST feature cut a square and triangle? Show a screen shot. What have you done to set this up? Did you download the driver for it and install it? Share this post Link to post Share on other sites
Harley Boyz Ken 0 Posted March 15, 2021 yes it's a vector design. the test feature is not cutting a square or triangle yes the driver is installed i did the full install set up Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted March 15, 2021 What is it doing? Can you show a screen shot? The cutter should make a TEST cut, right from the vinyl cutter TEST feature, with no software involved. Share this post Link to post Share on other sites
Harley Boyz Ken 0 Posted March 15, 2021 i can sent it in about an hour if that's ok. Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted March 15, 2021 ok. Also make sure that the wheels of the carriage head are firmly down in the track, they sometimes come out in shipping. Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted March 15, 2021 Concur with skeeter on making sure the carriage is engaged all the way on the track, see that quite a bit Share this post Link to post Share on other sites
Harley Boyz Ken 0 Posted March 15, 2021 ok i will check that first thanks for the help. Share this post Link to post Share on other sites
