zunimidniter@gmail.com 0 Posted February 1, 2021 I have a mk2 that's not cutting the entire image, it will only cut about 93% and just stop cutting with the progress bar on the computer showing 93% completed. I have this same issue a couple months back that IT helped me fix. I had to recreate the image from scratch (bad file) I tried doing the same but still have the same issue. Share this post Link to post Share on other sites
slice&dice 2,450 Posted February 1, 2021 Well, it's late, I'm watching the snowfall accumulate, let's take a crack at this one! First of all, midniter, what program is cutting? Now, I have heard there is a thing called a "Stray node" and from your description about the 'bad file' this may be something to explore. Since we cannot see the image you are trying to cut (you could post it, if you want) I am going out on a limb here and figuring it is composed of several (imported) elements? It's possible one of those contains the dreaded stray node. Let's look into this direction and see what comes of it. 1 Share this post Link to post Share on other sites
darcshadow 1,626 Posted February 1, 2021 Is it a large file that takes a long time to cut? Could be the computer is going to sleep or doing something weird. Also, are you using USB or serial? Share this post Link to post Share on other sites
