dvddvd 14 Posted January 19, 2021 Hi all I have a font called "Discoteque" and some letters have a flatened area which should be rounded, how can i edit it? It wont let me node edit it? As you can see the bottom left of the A has a flat bit and even the top is a bit flatterend? thanks a.vDoc Quote Share this post Link to post Share on other sites
haumana 1,220 Posted January 19, 2021 You would need to weld it, which will convert it to lines and curves instead of an editable font. 2 Quote Share this post Link to post Share on other sites
dvddvd 14 Posted January 19, 2021 thank you, that sorted it Quote Share this post Link to post Share on other sites
darcshadow 1,625 Posted January 20, 2021 If this is a problem with the font and you use this font often you can get font glyph editing tools and modify the font to suit your desire. I think illustrator has tools to edit fonts or there are several stand alone programs. Quote Share this post Link to post Share on other sites
RogerBrown 0 Posted January 20, 2021 11 hours ago, haumana said: You would need to weld it, which will convert it to lines and curves instead of an editable font. Thank you for advice. Quote Share this post Link to post Share on other sites
