AT-Dragon 1 Posted December 8, 2020 Hi, Does anyone know of a good reflective vinyl to use in a Epson ET7750 I’m looking for a permanent adhesive back outdoor vinyl, it’s fine if the vinyl will need a laminate just as long as it’s reflective and will print through a standard inkjet.. Thanks Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted December 8, 2020 7 hours ago, AT-Dragon said: Hi, Does anyone know of a good reflective vinyl to use in a Epson ET7750 I’m looking for a permanent adhesive back outdoor vinyl, it’s fine if the vinyl will need a laminate just as long as it’s reflective and will print through a standard inkjet.. Thanks inkjets cannot print on vinyl that is not specially coated to allow water based ink to adhere (and where that product will fail) 3m doesn't even recommend laminate over their reflective so they would never suggest a coating that would affect the reflectivity - you need to purchase a solvent, latex or thermo resin printer - or outsource it to someone with the proper equipment 1 Share this post Link to post Share on other sites
FirstChild 0 Posted May 11, 2021 On 12/8/2020 at 7:15 PM, Dakotagrafx said: inkjets cannot print on vinyl that is not specially coated to allow water based ink to adhere (and where that product will fail) 3m doesn't even recommend laminate over their reflective so they would never suggest a coating that would affect the reflectivity - you need to purchase a solvent, latex or thermo resin printer - or outsource it to someone with the proper equipment Good to know! Share this post Link to post Share on other sites
