X1ArmBanditx 9 Posted August 7, 2019 coming from(and i dont like admitting this ) silhouette studio, which is the easier transition? VM or scalp? i have access to both full legit programs and wondering which is the easiest to learn and get started with a new program..spent all night playing with the titan 3 se and WOW it is very smooth! and believe it or not my first cut was flawless and i havent had a bad cut yet! going to see how small i v=can get text today as soon as i decide which program imma dedicate my learning to also really dont want to, but if in a jam, will silhouette studio send files to the titan? thanks! Share this post Link to post Share on other sites
Dakotagrafx 7,296 Posted August 7, 2019 pretty sure silhouette studio will only send to the silhouette - scalp may be easier for your transition as it was originally designed for a cricut and oriented toward that market - Vinylmaster is very much preferred by most even though it will have somewhat of a learning curve - and you can upgrade to higher levels as you progress in your skills. I tried both and keep a copy of vinylmaster on my design computer along with my graphtec pro studio (which is private labeled flexisign) 1 1 Share this post Link to post Share on other sites
Wildgoose 4,198 Posted August 8, 2019 I agree with Dakota, VM may take more learning to switch over and will possibly cost more if you upgrade to Letter or Pro but is by far a better design and cut program. If you do go that route and do upgrade it I would go to the Pro level. There is also Expert but most of those tools come into play with printing. 1 1 Share this post Link to post Share on other sites
ShaneGreen 131 Posted August 8, 2019 I went to VM's youtube channel and whatched EVERY video, even the ones that didn't apply to me, and took a ton of notes. Rewinding and watching important parts over again. Then I upgraded to VM Pro and haven't looked back. It does have a bit of a learning curve, but it's a well thought out piece of software. It also has a number of features in Pro that are great when you're cutting multiple designs or copies. It seems to be focused on you running a vinyl business vs crafting. Just my 2 cents. . . 3 1 Share this post Link to post Share on other sites
