Meeshell 0 Posted May 28, 2019 Have a brand new Laserpoint 3 and when I send a print job it cuts, but the vinyl does not move/advance back and forth. It just cuts in the same spot. Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted May 28, 2019 Do you have the pinch rollers above directly over the grit rollers below and pinch rollers clamped down? You must to make the vinyl move. Also make sure you are not pulling from the roll while cutting. Always have enough vinyl slack to do the order. With the cutter turned off, can you manually move the grit rollers back and forth? Share this post Link to post Share on other sites
slice&dice 2,450 Posted May 29, 2019 Also, can you get the rollers to rotate in "offline" mode using the keypad arrows? (Manually adjusting as you would normally do to set origin) Share this post Link to post Share on other sites
