toonsign 0 Posted April 7, 2019 Hi, I don't use my Roland GX-24 often and when I went to cut some vinyl I keep getting a "Printer is in an error state" message. Everything is hooked up correctly but I did notice that when I first opened the program, it looked different. I can edit and do everything with the Cut Studio but just can't get it to cut. Uploaded new drivers (just in case) and still no change. Also, are there other cutters out there that can use any artwork created with the Roland Cut Studio? If I need to get another cutter I sure don't want to have to go thru the time making new cutter artwork. Thank you, Fred Melbourne Fl USMC Retired Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted April 7, 2019 PM sent and no you cannot use Cut Studio with another vinyl cutter. Only if you can export by .eps or another format for another cutter software to import. Share this post Link to post Share on other sites
