87sDetour 0 Posted March 22, 2019 I was trying to vectorize these faces but my vinyl master software takes all the color out when i do. Can somebody vectorize it for me please? logoface.psd Share this post Link to post Share on other sites
haumana 1,220 Posted March 22, 2019 LuvMyCrazyLogo.eps Share this post Link to post Share on other sites
87sDetour 0 Posted March 22, 2019 Thank you! can you do just the faces by themelves? there's a psd of the faces in the post Share this post Link to post Share on other sites
slice&dice 2,450 Posted March 22, 2019 Hmmmmm, that .eps does indeed import to SignBlazer, but cannot be sent to cutter as it is. 87sDetour, what are you seeking to accomplish with this? Share this post Link to post Share on other sites
87sDetour 0 Posted March 22, 2019 it's my logo for a product line. I'll have to cut it with vinyl cutter at some point but i'd also like to enlarge it and such. Pretty much everything possible. Share this post Link to post Share on other sites
slice&dice 2,450 Posted March 22, 2019 Just take the .eps provided and play around with it to your heart's content in Illustrator or Inkscape to obtain/isolate just the elements you require. It'll take a little bit of work to get a proper cut file, however. Share this post Link to post Share on other sites
darcshadow 1,626 Posted March 25, 2019 Little late to the party I realized. Is the PSD file suppose to be the same faces as in the logo image? Because when I open it, it is drastically different. In the PSD file I only see two colors, black and red and this can be quite easily vectored using VM. Import the image into VM, then select it and click on Images->Vectorize at the bottom of the new windows, on the left is a selection box that says colors, it will likely be 2, change it to 3 and you will see your preview image change to now include the red lips. hit Trace and you should be good. Share this post Link to post Share on other sites
