Larkin 0 Posted May 27, 2018 I have had a Laserpoint 2 for about 3 years. Before that I had Roland for 17 years. So I'm not new to cutters. Recently, I have had to turn off the cutter in between cuts and back on, seemingly to clear the memory. I run a lot of vinyl, and that has never happened before. In case it was a software issue, I downloaded a new copy and the issue is the same. It's not really that big of deal, but I am afraid that turning it off and on so much will damage the cutter. Any thoughts? Share this post Link to post Share on other sites
88x 74 Posted May 30, 2018 What cutting software are you using? The reason I ask is, I use SCALP 4 and used to have an LP2. Once after a software update mine would do the same thing, after a cut it wouldn't go back to the main menu on the cutter screen. Found that the update changed my cutter to something else, I switched it back to a laser point 2 and never had the issue again. 1 Share this post Link to post Share on other sites
Larkin 0 Posted May 30, 2018 Hi, I’m using VinylMaster Letter. I was using VinylMaster Cut which is the basic software that came with the cutter when the issue first started. I had been meaning to upgrade to Letter anyway so I did, hoping it would solve the issue, but no such luck. I have tried changing all sorts of options but so far nothing has helped. I appreciate the info Share this post Link to post Share on other sites
MZ SKEETER 4,728 Posted May 30, 2018 55 minutes ago, Larkin said: Hi, I’m using VinylMaster Letter. I was using VinylMaster Cut which is the basic software that came with the cutter when the issue first started. I had been meaning to upgrade to Letter anyway so I did, hoping it would solve the issue, but no such luck. I have tried changing all sorts of options but so far nothing has helped. I appreciate the info If your running it just on the USB,, put it on a serial cable or a Tripp-Lite Keyspan Adapter. That is the brand name. Has helped many people with value cutters. 1 Share this post Link to post Share on other sites
ShaneGreen 131 Posted May 31, 2018 I run a LPII off of a usb cable and have no problems (but others have) and VinylMaster Pro. It will run a 45 minute job (a dozen different decals set up as one cutfile), I change out vinyl colors and run another cutfile, multiple times, without needing to reboot anything. The same computer may also have 4 or 5 other programs open at the same time. Now I did have one issue I've ran into a couple of times you can look for. While it's cutting I've gone to another screen like File Explorer or Inkscape. When I go to cut again it either appears locked up or wants to cut the same thing again. What would happen is that VM had given a pop-up alert box but since I had another program open, the pop-up was buried and I didn't see it. The program couldn't operate until I took care of the pop-up. So next time it locks up look down in your task bar and see if VM may have an extra screen open that you don't see. 1 Share this post Link to post Share on other sites
