ign 5 0 Posted May 9, 2017 Hi all, looked through the forum, saw some older posts about this, but would like to hit this topic again, as hopefully new solutions. I am looking into trying to Print with my inkjet printer, and then laminate it, and then cut it in my Graphtec FC7000-100. SO questions are.... 1. What program could I use, that hopefully you have experience with using (can be paid program obviously, does not have to be freeware) 2. what materials would you recommend? 3. The overall process you do, and how well does it work? thanks in advance! -Russ Share this post Link to post Share on other sites
Dakotagrafx 7,298 Posted May 9, 2017 you can use vinylmaster pro some use aqueous vinyl that has been coated to accept water based ink to print using pigment ink and then laminate for personal use - not recommended for sale as the coating will break down and that is what usually causes the failure in this system. I saw some on a boat that had been there a year that were just starting to break down but with solvent, latex or thermo resin you will get over 3 years unlaminated and up to 8-9 years laminated with the right material Share this post Link to post Share on other sites
ign 5 0 Posted May 9, 2017 Thank you for your response. any links to tutorials on vinylmaster pro? or youtube links etc? Share this post Link to post Share on other sites
skarekrow 1,842 Posted May 9, 2017 https://www.youtube.com/user/futurecorporation/videos 1 Share this post Link to post Share on other sites
